Luke Afb, AZ
Just wanted to see what you guys prefer to do when prepping your chain? I’ve been hitting mine with brake cleaner and a toothbrush, then using a DuPont spray wax with Teflon. Seems to work okay without attracting too much dirt and dust, but curious to see what others do
Spray cassette with degreaser (cheap automotive stuff in aerosol)
Whip the park tool cyclone chain cleaner on with some more degreaser
whirr that bad boy around 20 odd times, rinse off with water.
For lube I really like the White Lightning "clean ride" wax.
Remove cassette and chain and soak overnight in mineral spirits every 2-3 months, scrub well with a dish brush, rinse with water and let dry. Lube with Rock N Roll once dry.
My personal choice is the below, copy/pasted from the article linked above:
"As long as your chain isn’t terribly dirty to begin with, washing it on the bike can yield excellent results. Requiring both degreaser and water, this is best done outdoors.
Remove the rear wheel.
Take off the rear wheel and install a chain keeper in its place. This will allow more thorough cassette cleaning, while also limiting how much degreaser gets into your hub bearings and on braking surfaces.
Use a brush and degreaser to remove the gunk from the chainrings and derailleur pulley wheels.
Brush degreaser onto the chain, backpedaling the chain through the brush at various angles.
Brush degreaser onto the cassette sprockets; a larger brush will speed up the process.
Rinse off the cassette, chain, chainrings, and derailleur pulleys with a low-pressure stream of water. Avoid squirting water directly into any bearings.
Dry everything with a clean rag, and then set the bike aside to air dry further. Alternatively, use compressed air to speed up the process.
Remove chain keeper, reinstall rear wheel, and apply your lube of choice.
Apartment Tip: Use a self-service car wash if your bike is really grubby. It’s a washer on demand, with fluids collected and recycled.
Alternative: Use a chain cleaning device instead of brushing degreaser on the chain. These use a number of rotating brushes that automatically scrub the chain’s inner links, outer links, and rollers. You can also use these to better contain the mess of washing, or as a final rinse by replacing the degreaser with water."
Then I dry my bike in the sun and spritz the chain with a motorcycle chain lube. That stuff is too heavy and definitely overkill for a bicycle chain, so I wipe a lot of excess off for a while.
Additionally, i find that synthetic lubes work worlds better than conventional ones. conventional lubes have to try to combine the lubricity of an oil, with the chain protection of a wax, using various combinations of those elements. Synthetics can use engineered formulas that can combine both properties into one substance, which, IMO, works better than conventional lubes ever can.
I wipe down the chain with a rag every week or so, some toothbrush action if there is more greasy crap on the plates. Dry lube applied to the rollers link by link so you're not wasting oil/ putting more stuff on the chain that will attract more dust. Wait for the solution of the dry lube to dry and then wipe the outside to remove any excess. Degreaser gets used maybe ever other month.
Also a quick wipe down/ scrub of the derailleur pulleys since those seem to love to collect dust/oil
I initially wasn't using the liquid chain lube on my MTB but just added it when it's close to requiring a fresh wax to stretch out interval. I have considered adding teflon but didn't want to add any more "forever" chemicals than needed. Did you try with and without? Notice any difference?
Well, they say teflon is inert and the little amount that gets left in the environment from our biking probably doesn't compare to other contaminants like hydrocarbons or carbon fiber.
Clean thoroughly, like take the chain out and cassete and thinner the thing until squeaky clean.
After I use Motul offroad chain lube (spray) and let it soak. The cassete gets a treatment with WD40, just a spray on a rag and the rag on the cassete.
The other day I pick the chain and apply the same wd40 on the outer links, removing the excess of lube and leaving a smidge of WD40. Before installing everything back in the bike, I use a clean rag to wipe everything down.
Since then, I've done this once a month. The good part is that it seems to be always clean (golden chain!) When it's muddy, a hose clears the mud away, and since the lube is not wax, it stay longer where it's important.
This way is way more involving, but I do this once a month, so to me it's easyer.
Btw 10:1 wax to teflon is way in excess of what's needed. I use significantly less (although i cant remember my ratios atm) and have never had an issue. Whilst that concentration isn't going to be doing harm, it is reducing the effective yield of your ingredients.
Full clean w/ degreaser in an actual chain cleaner. Numerous water rinses until squeaky clean. Then air compressor dry, followed by Dumonde Tech to rollers. Cycle chain to spread lube to inner parts. Wipe off excess.
Interim: wipe off dirt/gunk w/ rag, reapply lube. I don’t do this more than “in a pinch” to limit dirt in chain causing actually harm. Helps when chain starts to make noise if no time to do full clean.
After mud rides, hose clean while cycling chain. Rag wipe clean. Compressor dry while wiping. Relube rollers.
I have problems but bike gear/tools isn’t one.
I stripped and hot waxed 4 chains for two bikes about 5 weeks ago and am still using the first two now almost completely unserviced. I live in the US north east and it’s been a very dry summer so that probably factors in to the lack of maintenance.
My wife didn’t want me hot waxing her chains so I used the Smoove on her chains bikes and they have needed a bit more maintenance in that time. All the chains are super quiet and appear very clean. I definitely won’t be going back to oil based lubes at least not for summer/dry riding.
I have a bike that I leave with a friend in SoCal where my work’s home office is and I plan to hot wax the chain for that bike too (whenever traveling for work is a thing again). I doubt I will have to relube that bike more than once a year.
I would say the effort to prep the chain in the beginning seems to even out pretty quickly.
Edit: formatting
As everyone has mentioned the majority of effort involved is in the cleaning and degreasing of the chain and that's something everyone should be doing anyway. I'm sure a thorough off bike clean and deg would benefit conventional lube users too.
The wax method is so effective I use it on my garage door chain and mx bike. The latter allows me to use much cheaper plain chains than the o ring chains most guys run. I'm about to use wax on a moving roof project to ensure the chain drive never needs any maintenance in their lifetime.
I've also made up some ice cube molded blocks of wax lube that I use in heaps of places around the house and farm. You would be surprised how many places benefit from an application of a good quality dry lube.
-Open Beer
-Drink a sip of beer
-Rinse bike with water
-Spray Muc-Off on bike
-Brush whole bike with brush
-Rinse off bike with water
-Bounce bike hard on gronud 4-5 times to get water off
-Dry whole bike with old towel
-Apply Rock"n"Roll Gold on chain
-Finish beer
-Dry off excess lube with rag
-Hang bike on it's place in my hallway.
Post a reply to: How do you clean/lube your chain?
