rockchomper rockchomper
5/29/2020 11:51 AM
A brilliant solution on a homemade "Hall Lock" for Sram and Shiamno derailleurs from my buddy Collin Timmermans!
| Quote
Sesame Seed Sesame Seed
5/30/2020 8:44 AM
It's the taking something DH Race focused with insistance upon it working the same on trails that's seeming to be overlooked. Used to try this w/ Dyna-Sys 9-speed - busted deraileurs were a result then also.
Using M9000 XTR on a vague ride-everywhere-up-and-down-bike-shaped-thing and, no noise or wear. Shimano's sensible XTR 11-40 cassette has less leverage from any increases in cage rotation, clutch is set as light as can be and I run a full chainguide.
| Quote
6/1/2020 8:06 AM
I just got my AL washer so ill be trying this hack out this weekend, I will report back with how it worked for me!
| Quote
Jon_Angieri Jon_Angieri
6/2/2020 7:29 PM
rockchomper wrote:
I just got my AL washer so ...more
Bought the spacer from the link you posted on Pinkbike. Can’t wait to try it out as well. Are you running SRAM or Shimano??
| Quote
6/3/2020 8:01 AM
Jon_Angieri wrote:
Bought the spacer from the ...more
I am Running SRAM GX 7 Speed for my DH rig but although im not sure, I do think that washer will work with the sram one too.
| Quote
6/8/2020 6:49 PM
rockchomper wrote:
I am Running SRAM GX 7 ...more
I’m running XO1 Eagle derailleur. Got my washers in today. Going to try it out tomorrow. Have you had a chance to test it yet??
| Quote
6/9/2020 12:42 PM
Jon_Angieri wrote:
I’m running XO1 Eagle ...more
Yes I did try it out and its so freaking silent!!!! ill link a video in the next few minutes to show how quiet it is!
i put it on my bike and my friends bike and both of our derailleurs did not have the ring holding the b screw stop in, it was actually easier to remove you just unscrew while pushing the bolt out, it also helps if you remove the small oring that fits under the b-screw stop plate (the oring on the bolt closer to the threads) do not remove any other orings. I cant recommend this hack enough. stay tuned for a short clip of me smashing through steep chunk with it installed!
| Quote
6/9/2020 12:58 PM
Make sure your Volume is up! My bike is now silent!
https://www.pinkbike.com/video/518361/
its probably also mentioning I have covers on my internal cables, the link below shows cheap cable covers and you dont have to remove anything to install them. check you internal cable routing holes to see if you need 1/8 or 1/4. if your unsure go 1/8in.
https://www.mcmaster.com/1459T811
| Quote
Barry Barry
6/11/2020 12:07 AM
You can do the same thing by using loctite on the shimano derailleur and the cheaper sram derailleur hanger mount bolts and loctite the bolt in place with a retaining compound
Then on the higher spec sram derailleur where there is a separate bushing, you can file the bushing down by 2mm when the derailleur mount bolt is tightened it locks the mech in place as the bushing is shorter and doesn’t bottom out.
Using loctite retaining compound improves this again.
Far better than having less threads of the bolt holding your derailleur on.
| Quote
Philip_Rossetti Philip_Rossetti
6/11/2020 4:39 AM
Testing this on my xt 12 speed. I’ll give it a try and see if it makes a difference! My bike wasn’t loud before but maybe this will make her even better! I used a brass spacer from the hardware store with a 12mm internal diameter and it fit like a glove!
| Quote
6/11/2020 8:02 AM
just in case anyone is looking for the washer to use on a sram derailluer and also some of the newer shimanos here is a link:
https://www.clipsandfasteners.com/Aluminum-Washer-10mm-I-D-16mm-O-D-1mm-Thick-p/caf1029-10.htm
this is the perfect fitting aluminum washer for SRAM and it comes a pack of 10
| Quote
therock911 therock911
6/11/2020 11:42 AM
Would this have any affect on shifting performance?
| Quote
6/11/2020 1:31 PM
therock911 wrote:
Would this have any affect ...more
Nope, i've been running in and it shifts perfectly fine! also its break for the breaking bumps at bike parks as those are known to damage b screws and this locks it into place so that it doesn't smash up your screw. Its pretty legit I can see why it is a standard feature on the new TRP derailleur.
| Quote
6/11/2020 2:26 PM
rockchomper wrote:
Nope, i've been running in ...more
I see. I guess my thinking is was there a reason why derailleur's were like this in the first place? Just for easy wheel removal?
| Quote
6/11/2020 3:31 PM
therock911 wrote:
I see. I guess my thinking ...more
the reason its not set from the factory is different frames, cassettes, jockey wheels, ect. means that the b screw needs to be adjusted differently so they allow movement for adjustment, but once adjusted it no longer needs to be have movement. So once you have you b screw properly set you can lock it in with this trick eliminating the movement which causes noise and damaged b screws. Its the exact same thing trp did with they're new derailleur.
| Quote
6/23/2020 8:02 AM
After two weeks of riding with this hack I have to say it maker literally no difference whatsoever. It might work better on some other suspension platforms but in my bike there is no noticeable change
| Quote
Post a Reply
