btn
btn
5 of 25
groghunter groghunter
2/26/2020 7:37 AM
Pedal4life wrote:
Honda with there GL1800 ...more
do you have a source on that? only article i can find on the subject says that they did it because the vertical axle path let them move the engine, and therefore the rider, more forward on the bike.
| Quote
Primoz Primoz
2/26/2020 1:14 PM
Good point about the stiction, yeah. I mentioned that USD forks should be stiffer in longitudinal direction since the tubes are larger (and/or thicker) in the place where the bending moment is higher - towards the crown.
| Quote
Colin McCarthy Colin McCarthy
2/26/2020 4:25 PM
Boxxer is listed at 5.76 lbs and Bartlett is 5.7 lbs so it’s 27 grams lighter, which almost an ounce. The Bartlett has a boost 15mm axle whereas the Boxxer is boost 20mm, so if you go with the Boxxer, you also need a different wheel.
| Quote
vweb vweb
2/27/2020 12:13 AM
Colin McCarthy wrote:
Boxxer is listed at 5.76 ...more
It is only future-proofing (having 20x110 Boost front axle) IMO...
| Quote
Sir HC Sir HC
2/27/2020 12:54 AM
Shimano Saint 2020? Or are they going to leave it for another year? Not seen any proto parts about, the spd pedals were around for a while before a full version made it to market.
| Quote
trailfurnace trailfurnace
2/27/2020 4:29 AM
Revel's new fusion-fiber Revel Fusion-Fiber wheels
| Quote
2/27/2020 7:23 AM
Sir HC wrote:
Shimano Saint 2020? Or are ...more
This is honestly my most anticipated tech news right now. Saint is loooooooong in the tooth.
| Quote
bermslapper69 bermslapper69
2/27/2020 7:30 AM
| Quote
Primoz Primoz
2/27/2020 7:36 AM
Shimano and FOX stuff based on what Greg showed up to this point. And the Devinci Spartan is what, 1 year old at this point?
| Quote
Primoz Primoz
2/27/2020 8:03 AM
I would have expected a change to 15 mm would occur with Boost hubs instead of the 20 mm boost standard coming out. But it's hard to see how that would get sold. You can't sell stiffness, it's hard to sell weight to DH guys (the way I see it at least), in the rear going 135, 142 or 148 gives you supposed width advantage over the 150/157 hubs (narrower frame, 'harder to snag rocks'), etc.
Interestingly, 15 mm hubs should be more durable though. With bicycles using disc brakes you are limited with how big of an OD bearing you can put in the non-drive side of the hub. With a 15 mm axle, you get some more space for the bearing on the ID. That means larger balls and, in practice (considering the load carrying ability specification of said bearings), more strength. And that means more durability.
Ah, the details smile
| Quote
brapp_juice brapp_juice
2/27/2020 8:20 AM
BIKES!
| Quote
Primoz Primoz
2/27/2020 8:36 AM
TBH, if I'd do research on linkage forks, I'd be head on into research of fully integrated versions like Structure Cycleworks. If you're going at it, might as well go all in.
| Quote
2/27/2020 3:37 PM
It was just the current spartan but with all the new devinci sponsors. Paint job looks sweet tho, wonder if that’ll be available to the public.
| Quote
2/27/2020 5:28 PM
Wide range TRP drivetrain coming soon? Looks like it says trp on the rear and the styling/general shape seems similar to their DH derailleur.
| Quote
Mo(n)arch Mo(n)arch
2/28/2020 12:04 AM
No posts about the new Fox shocks?
| Quote
Maxipedia Maxipedia
2/28/2020 10:02 AM
In other news, it seems that the boys at 50:01 are about to launch a range of technical apparel:
https://www.facebook.com/50to01/videos/697195354351689/
| Quote
Primoz Primoz
2/28/2020 2:48 PM
Well, the 20 mm hubs use the BB tool instead of the cassette tool, so not 'THAT' different as opposed to the cassette tool.
15 mm was developed with Fox, yeah, but dunno, to say it was only developed because of center lock? That seems a bit of a stretch to me... It might have been an influencing factor, but i doubt it was the only one.
| Quote
ka_mtb_nv ka_mtb_nv
2/28/2020 3:00 PM
It looks like Bubba Warren is riding a new Evil Following. Photo
| Quote
Maxipedia Maxipedia
2/28/2020 3:49 PM
Well, the 20 mm hubs use ...more
Why didn't they use the 20 mm axle that everybody was happy with, then? Remember 20 mm Reba's? wink
Yes, I forgot that you open it with a BB tool, because I avoid Centerlock as much as possible. And don't forget Shimano has quite some history in wanting to shove us their ”innovation” down the throat: Biopace, initial Octalink, those damn Dual Control levers etc
| Quote
GUILLO GUILLO
2/29/2020 3:54 AM
The new 38 with Kashima? Photo
| Quote
Martin_Prophet Martin_Prophet
2/29/2020 4:52 AM
Looks like the syndicate testing the Mullet
| Quote
Brian_Peterson Brian_Peterson
2/29/2020 6:31 AM
Why didn't they use the 20 ...more
Also remember they pitched that a 15mm axle was lighter without a significant loss of strength...
| Quote
mwolpin mwolpin
2/29/2020 2:16 PM
Martin_Prophet wrote:
Looks like the syndicate ...more
Is it me, or does the front triangle look different compared to the current V10?
| Quote
Primoz Primoz
2/29/2020 2:19 PM
I think it's just the paint.
| Quote
mfoga mfoga
2/29/2020 2:42 PM
I love centerlock for travel. So much quicker to remove and install for packing a bike.
| Quote
mwolpin mwolpin
2/29/2020 2:44 PM
I think it's just the ...more
Yeah. I was thinking that too, but the red area at the shock mount position looks a bit more vertical and taller. Here’s a stick image of a V10.
https://marvel-b1-cdn.bc0a.com/f00000000168805/cdn.shopify.com/s/files/1/0016/3856/3907/products/v10ccxo1275blk_1800x1800.jpg?v=1571714529
| Quote
Big Bird Big Bird
2/29/2020 4:39 PM
mwolpin wrote:
Yeah. I was thinking that ...more
We might just be looking at different sized frames.
| Quote
mwolpin mwolpin
2/29/2020 4:44 PM
We might just be looking ...more
No need to bring logic to the Internet. smile
| Quote
Big Bird Big Bird
2/29/2020 7:10 PM
mwolpin wrote:
No need to bring logic to ...more
So glad to hand on the Face in Hand Award.
| Quote
Jrp Jrp
2/29/2020 10:48 PM
New 38 also has lowers air bleed ports and axle pinch bolts. Apparently it’s very heavy
| Quote
5 of 25
Post a Reply
