Sir HC
8/17/2020 12:33am
Oh god... 'We can't fit the shock to the frame... Let's make a completely custom shock that no one ever will stock parts to service and...
Oh god... 'We can't fit the shock to the frame... Let's make a completely custom shock that no one ever will stock parts to service and won't know how to service it!'
Logic.
I'd love to see the process which the crayon holders use to come up with these bikes. Bike like the rail should fit any shock.
Bike industry has planned obsolescence and early life failure down to a tee though! Saw a video of the Levo SL, open up the charge plug and there is water in there...
rugbyred
8/17/2020 1:53pm
[img]https://p.vitalmtb.com/photos/forums/2020/08/17/9840/s1200_913D0CE8_774B_41C7_9F96_2FE1B3E92087.jpg[/img]
I think he might mean that the first race is in 14 days
8/17/2020 2:53pm
I’m not referring to the “14 days” but to the frame and 38. I don’t think he would put a 38 on a 130mm bike
Poleczechy
Wheat Ridge, CO US
8/17/2020 3:04pm Edited Date/Time 8/17/2020 3:04pm
No head tube badge or any other Forbidden branding either.
rugbyred
8/17/2020 6:09pm
Proof that I don’t know much!
8/17/2020 9:52pm
With a completely electronic system and a 6 speed cassette with the correct ratios, you could halve the cassette width and still keep the current 12 speeds and their ratios. Which would be beneficial for the chain line, spoke angles and so on. Might even be possible to go back to narrower rear ends with relatively wide spoke spacing.
Masjo
Ancaster CA
8/18/2020 8:15am
With a completely electronic system and a 6 speed cassette with the correct ratios, you could halve the cassette width and still keep the current 12...
The system above offers 1:1 and 1:0.7 so you would still have to run a 9 speed to get the same number of gear ratios. It is certainly an interesting product and line of thought. I'm sure with a dedicated MTB hub built with larger cassettes in mind (even if the 'minimum' was 34 instead of 28) the extra real estate in the hub could potentially offer better sealing or more range.
8/18/2020 10:22pm Edited Date/Time 8/18/2020 10:22pm
Masjo wrote:
The system above offers 1:1 and 1:0.7 so you would still have to run a 9 speed to get the same number of gear ratios. It...
Nope, 6 cogs can give you 12 ratios Wink
I'll write a bit more about this in the afternoon, I already did some quick calculations in Excel yesterday.
big b
harrisburg, PA US
8/19/2020 4:19am
Trek has dropped the Reactiv shock for the 2021 Remedy as well as the 2021 Slash.
8/19/2020 5:01am
stringbean wrote:
Thoughts on this having a place in the MTB world? https://cyclingtips.com/2020/07/this-rear-hub-has-2x-wireless-shifting-inside-and-11-gears-on-the-outside/[img]https://cdn-cyclingtips.pressidium.com/wp-content/uploads/2020/07/Classified-hub-internals.jpg[/img]
Hammerschmidt did it first/better.
I would love a new, lighter Hammerschmidt that you could pair with the e*13 DH cassette and an even smaller derailleur....
Masjo
Ancaster CA
8/19/2020 5:25am
Nope, 6 cogs can give you 12 ratios ;) I'll write a bit more about this in the afternoon, I already did some quick calculations in...
You are definitely correct! I was thinking gear range, my bad.
Norristown, PA US
8/19/2020 1:02pm
i've always felt / said that the hammerschmidt was ahead of its time.
8/20/2020 8:46am
Not technically new technology but here’s another brand selling the Mullet setup straight from the factory. Seems like it’s almost part for part the same bike that wyn and Martin are racing on
8/20/2020 9:38am
I actually read it as that. Anywho, the way I'd use this, completely integrated, is with a cassette of 6 cogs, which would be 10, 14, 19, 26, 35 and 49. With a ~0,85 easy gear ratio of this planetary gearbox, you very nicely drop just in the middle 'cogs' of the cassette once engaged (as opposed to 1:1 ratio), meaning you get virtual 11,8, 16,5, 22,4, 30,7, 41,3 and 57,8 toothed cogs. And almost 580% of range.
The planetary gearbox ratio was determined by trial and error, same goes for the cassette (smaller cogs emant weird jumps between gears in at least one part of the cassette) and it gives a very smooth drivetrain jumps wise with a minimal jump of 14 % (only one under 15 %, going from 30,7 to 35 'cog'), max jump of 18,6 % and an average jump of 17 %.
Pic (jump 1 is 10 to '11,8' or 10 underdriven):
I've added the current crop of Sram Eagle systems (shows how utterly stupid the 52T cassette is) and Shimanos' 10-51 cassette. This combo geartrain is more constant throughout the range than both and gives more range than both as well.
How to achieve that? You start in the 10T cog and in 1:1 mode on the planetary. Pressing the shifter to choose 1 gear lighter switches the internal hub. Pressing it again switches BOTH the internal hub and the chain on the cassette.
Minuses? The jumps on the cassette are very big, it might be hard to get reliable shifting with the current state of affairs, shift ramps in the style of front shifting might be needed. And I don't see this happening without electronic shifting as you simultaneously shift two different systems. And the timing of the shifts might be an issue. It maybe could be possible with a twin indexing system in the trigger shifter by using two cables, but yeah, this is a challenge.
The benefits? Narrower cassette, narrower hubs and/or wider flange spacing on the hubs. That's the main thing and I don't think it'd be worth it unless either Sram or Shimano went that route for total integration. As to why? Well if you have a system that shifts smoothly under full load, you want to use it all the time. It doesn't make sense to me to use with a DH cassette or as a Hammerschmidt, because those are cassette double-uppers, where, once you reach one end of it, you have to move across the WHOLE cassette (and shift the fast and smooth mechanism only once) in order to get to the 'next gear'. And we all know how well that turns out. So why not use it all the time? I agree, using small DH like clusters seems nice (weight wise, production cost wise, shifting performance wise), but the negative, in my opinion, is just too great. You're effectively back to 2x gears of yore. And nobody likes those too much, the simplicity of 1x systems is just awesome.
8/20/2020 9:49am
Yes and no. The issue with Hammerschmidt for example was that it wasn't really compatible with the bikes it was put on. Because it was mostly an either-or spec list with 2x drivetrains. And when you design antisquat curves for ~32T chainrings (or larger), the 22T (was it 22T?) of the Hammerschmidt will cause unwanted bob. Design a bike specifically for a Hammerschmidt and a normal 2x drivetrain will be crappy.
It would work very well with the current crop of idler bikes though, there would be no antisquat changes there.
8/20/2020 10:07am
Hoping the cockpit will be decently long on this one as opposed to the Druid (which is something between an M and an L length wise in their XL size).
Arobb123
8/21/2020 10:03am Edited Date/Time 8/21/2020 10:06am
One of the Cannondale lads is riding an interesting bike in the new 50to01 video, looks like the proto dh bike from last year but eagle drivetrain suggests maybe more of a long travel "superenduro" type bike
8/21/2020 11:04am
To me it looks like Ratboy just took the prototype Dh and put an eagle on to climb up to the top of revs Wink
8/21/2020 11:27am
It's the bike that has been seen in the whistler lienup before. It's an 'enduro' thing, this isn't the DH bike as it doesn't have any front/upper shock mounts.
8/21/2020 11:28am
Arobb123 wrote:
One of the Cannondale lads is riding an interesting bike in the new 50to01 video, looks like the proto dh bike from last year but eagle...
I posted about it a few days back. It looked like the proto habit.
8/21/2020 11:38am
Saw that exact proto at Mountain creek a few weeks back. Doesn't have an upper shock mount, but does have a mottle cage mount. That particular bike did not have a dual crown fork, instead it had a 170 mm fox 36, and Float X2.
8/22/2020 2:23pm
Yea the DH based c-dale Enduro bike has been floating around this and the 2020 team rumors thread since last year. Waiting on those numbers and it's time to own a Cannondale.....
Darth_Sloth
8/24/2020 3:32am
You can actually buy the new Slash at the moment, but no press release? Weird. Reading the comments there the new Knockblock 2.0 is removable and isn’t required if you dont want it.
