AT texted the dimensions of the jumps in his contest, so it should be a good starting point for ya.
- big ramps - 8ft tall with 14ft radius
- smaller ramp (last jump) - 6ft tall with 10ft radius
depends if you want height or distance.. i usually cut all mine at around 12" 6inch radius @ 6ft .. my gap is usually around 12ft lip to landing..
a 10ft Radius is going to pop you nice.. however.. you won't be able to do quite as much at higher speeds...i guess it depends on your riding style and what you're doing.
Thanks for the numbers and pictures, super helpful... I ended up going with a 10' radius and kept it small, around 4'6" tall. The landing is mulch, piled up behind a rock wall (don't come up short!!!). It's also a little bit of a step-up so the landing is very forgiving. This thing is perfect for me for now, I see larger ones in the future....
- big ramps - 8ft tall...
Good to know.
We will be replacing a couple dirt jumps with larger wood kickers this summer.
Anyone have the numbers of the Post Canyon Booters?
14' seems like a good test case. We will be constructing soon, dirt is almost soft enough to manage again.
The take-off in my avatar is going to be the first one replaced with a larger wood version. Thanks for the info everyone.
Im a big fan of the Wood Kicker, is this what you had in mind?
FMX left side jumps in PC have a 10-14 foot radius, I believe.
there thats better, our trailer ramp with jack lifts in the front.
and here is me standing 6'4 tall next to the rampage canyon gap for rampage 2012. talk about a big wood ramp
Post a reply to: WOOD LIPS
