brake oil dot5.1 .. ??
Edited Date/Time 8/16/2014 5:24am
Hi guys,
Wonder if wrongly use hydraulic brake oil dot 4 ...instate of dot 5.1 ... can the brake oil dot 4 be flushed .. ??
Will my brake caliper get faulty ? o-ring or seal get faulty ?
Hope some one could help out ...
12/12/2011 10:25am
This is why I like brakes that use mineral oil. You'll have to check with the brake manufacturer on this one. The fluids should flush pretty well, but as for residual damage, call the man.
pro_fro
Ashland, OR US
12/15/2011 1:08pm
dot 4 should be fine.
I'll oxidize quicker if left out. but if you're running a closed system and have your bottle open for no more than 20 minutes at a time you should be in good shape.
I like to run the 5.1 stuff from the auto parts store.
wayyyy cheaper than o.e. kits
that's my 2 cents
The-Hoff
Ketchum, ID US
12/15/2011 6:59pm
I was actually talking to the guys at Avid about this yesterday. Dot 4 fluid will be fine, but won't function nearly as well as 5.1 because it has a lower boiling point, meaning it cannot handle the higher temperatures that come with downhill riding. Whatever you do though DO NOT USE DOT 5 FLUID! The previous owner of my brakes had them shop bled and the mechanic used dot 5. The o-rings are now coming apart, and chunks of them are flushed out when I bleed them. This is at least what I got from my talk with those guys yesterday.
pro_fro
Ashland, OR US
12/16/2011 2:29pm Edited Date/Time 12/16/2011 2:36pm
The-Hoff wrote:
I was actually talking to the guys at Avid about this yesterday. Dot 4 fluid will be fine, but won't function nearly as well as 5.1...
http://www.pricepoint.com/detail/21712-115_AVDBF1-3-Parts-158-Brakes/Di…
huh, yeah, I wouldn't use avid's own products either.....
pro_fro
Ashland, OR US
12/16/2011 2:46pm
ohhh shoot!
my bad. 5.1= good.
my reading ability = poor.
Post a reply to: brake oil dot5.1 .. ??
