Sounds like you need something a bit burlier. Sun Ringle Rhyno Lites are decent, and they are usually pretty cheap. Make sure to get the welded variety. 36 spokes instead of 32.
ya i dont think they make the sun ringle rhyno lites welded... kinda sucks..... but with a 26in rim is it more likly to bend with spin tricks? should i go down to a 24
You might want to check out the Azonic Outlaw Wheelset. They are pretty cheap compared to a lot of other wheels yet are still strong and they come in a variety of colors. I have used them on my Dirt Jump bike for a year now with no problems.
I personally have been running Atom Lab Trail Pimps... they have outlasted 2 frames and a fork. I have 3 spokes missing, and have for months, and they are still reasonably true. I'll be buying them again if they ever get too beat!
I personally have been running Atom Lab Trail Pimps... they have outlasted 2 frames and a fork. I have 3 spokes missing, and have for months...
their are 2 diff rhynolites the reg for xc witch is pinned then their is the rhyno lite XL witch has a welded joint, eyelets and is much wider and makes for a nearly bombproof wheel can be had on many websites fairly cheap if you can swing it look for a wheel builder after you buy any factory assembled wheels and have them retensioned or taken apart and reassembled by the wheelbuilder it may cost an hr labor but youll and up with a better stonger wheel . I personally have a set i have on one of my bikes reassmbled by a good wheel guy had them now since 2001 only trued the rear 4 times the front twice i am like 250lbs and do alot of urban riding such as stairgaps loading docks lots of drops and jumps to flat . lotsof city riding etc. so i know they will hold up just remember ifyou go ryhnolite get the XL in either 32h or 36h .
Sun RIngle MTX39s are pretty indestructible. Probably a bit heavy for what you're doing, but you'll have a hard time hurting them.
For DJ I've been using Azonic Outlaws for quite a while and they're solid.
Trail pimps are the way to go! I rode them on my downhill for a season then threw then on My DJ and I have not had to tru them yet. Only problem they are just a bit more expensive than most. Also look at the spank subrosas they are light and strong.
They are strong and farly cheap
You can get them in all kinds of crazy colors to
Post a reply to: i need strong rims
